ACADuser Posted May 29, 2024 Share Posted May 29, 2024 I'm going on a 15 day vacation and the Architect I produce plans for is concerned that a plan issue may come up while I'm away. I have uploaded all the relevant folders to my DropBox & given him access. But all he can do is modify pdf & he works in Sketch-up. So I thought he may start a trial version for $200 if he actually needed to modify the files. I don't have a lap top so that is not an option. If the trial version is X16 he could download the plan & layout file to do modifications don't you think? What do you think? Link to comment Share on other sites More sharing options...
JiAngelo Posted May 29, 2024 Share Posted May 29, 2024 Deactivate your license on your computer, enter your license on his computer for his use while you are gone then revert everything when.you get back. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted May 30, 2024 Share Posted May 30, 2024 Technically, if he pays the $200, he is not using a "trial version". He is just subscribing the same way any other new user would with no commitments beyond that first month. The biggest problem is probably going to be the learning curve. If he is used to sketch up, he will probably go crazy trying to figure out how to do what he wants in Chief. You may get a few "how do I..." types of calls. Of course there's always the risk that he actually really likes Chief, decides to keep subscribing, and then stops hiring you to do his plans. 1 Link to comment Share on other sites More sharing options...
ACADuser Posted May 31, 2024 Author Share Posted May 31, 2024 So true but he likes sketch up. True that is a subscription. I found someone with Chief skills to step in if needed Link to comment Share on other sites More sharing options...
