kathrynmc Posted May 28 Share Posted May 28 Good morning! I imported a light fixture from an online catalog and while I altered the item wherever I could to electrical it is not able to snap to my lighting chain... What should I be doing... Also does anyone have a great TV outlet item with CAD? Link to comment Share on other sites More sharing options...
DG1949 Posted May 28 Share Posted May 28 In the Options panel, make sure Ceiling Mounted, 110 Volts, and Switched are ticked. Link to comment Share on other sites More sharing options...
DBCooper Posted May 28 Share Posted May 28 When you imported the symbol, you made it a "fixture" (I can tell because it says "fixture" in your dialog). You need to re-import it and make it an "electrical" object instead. Link to comment Share on other sites More sharing options...
DBCooper Posted May 28 Share Posted May 28 I just realized that in X16 you can now connect electrical objects to fixtures. I think in your case even if you are using X16, you probably still want to re-import your object as an electrical object so that you can add lighting information to it. Link to comment Share on other sites More sharing options...
