Need Gravel to show
Chiefnewell
  • Chiefnewell changed the title to Need Gravel to show
43 minutes ago, Chiefnewell said:
Need gravel under carport showing.. Cannot get it to show. I do not know why it is showing a design. just plain gravel.
So you want the gravel to show on top of the conc slab?  I am assuming not, but that's what you have in your room dbx.  You had the foam and gravel as flooring, with a slab underneath.  Actually, you have two slabs.  One in the room DBX but other as a terrain feature.  Delete that feature and that pattern will go away from your plan view.
Once that is deleted, go back to your dbx and pick "Floor under this room" and your gravel will appear, so will your foam and slab.  Adjust accordingly...
Hope this helps!
Michael gave you a simple way to fix the issue. It's better to adjust your way of thinking to how Chief wants you to think - "slab" being the floor under the room, not necessarily a concrete slab.
The model has a handful of problems in this area but if you only want to fix the material & fill pattern shown just select the displayed slab at your carport (it's a terrain feature that you placed, 1" thick with a concrete material) and change that concrete material to the river rock that you were trying to use as gravel. Then adjust the bounds of that terrain feature however you'd like, in case it's extending out to the street or something.
Then, on whatever plan view you are trying to show this on, make sure that your terrain feature layer is displayed. And the design being showed is something that you must have accidentally set so in that terrain feature's DBX, set the fill style to whatever it is you're looking for (you have decorative block shown, hence the pattern).
Plan view shows the selected fill type.
Most 3D views will show the material.
