Rayt Trace Color Changes
RL-inc
I have played with the ambient color settings as well as the environment light color but still my raytrace view is coming out with a pink hue compared to the render view which is much closer to the actual libray material.
any ideas
Accurate colours and textures are extremely important for me. Those depicted in the camera views are often way off from the Raytrace . The best approach I have been able to find is to select the material in question and use the blend with color pallet and shift the colour to get the render correct. For interiors you can also set the colour temperature on the lights which will influence a colour, same as adjusting the white balance in photography. Don't know if you can do this with in the sun settings for exterior rendering.
Graham
