Breeze_Design Posted May 11, 2024 Share Posted May 11, 2024 Has anyone found this cabinet in Has anyone found this cabinet in a CA library? Or on sketchup? 4 tried searching for it but no luck Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 11, 2024 Share Posted May 11, 2024 16 minutes ago, Breeze_Design said: Has anyone found this cabinet in Has anyone found this cabinet in a CA library? Or on sketchup? 4 tried searching for it but no luck Should just make this one yourself. Custom Cabinet Door Link to comment Share on other sites More sharing options...
Breeze_Design Posted May 11, 2024 Author Share Posted May 11, 2024 2 minutes ago, Renerabbitt said: Should just make this one yourself. Custom Cabinet Door sounds like i will have to learn this skill Link to comment Share on other sites More sharing options...
Solution MarkMc Posted May 14, 2024 Solution Share Posted May 14, 2024 On 5/11/2024 at 6:23 PM, Breeze_Design said: sounds like i will have to learn this skill Yes you should BUT calling it a custom cabinet door is a bit oversimplified. More like 3 custom doors and some tricky cabinet manipulation. At least the only way I know. Parts from a recent one with an adjustment close to yours I think, sides may be a little different. Open everything in the attached plan, every tab, then try on your own. ' valet cab.zip 1 Link to comment Share on other sites More sharing options...
MarkMc Posted May 14, 2024 Share Posted May 14, 2024 I should have mentioned that the cabinet supplied measures 25.5 inches wide. The Y offset for the hutch side can be set to zero. Then the cabinet would measure 24. There will be some other issues in vector view that's tricky to clean up. The shelf fixture symbol might need adjustment then. Which way depends on what's most important. 1 Link to comment Share on other sites More sharing options...
Breeze_Design Posted May 14, 2024 Author Share Posted May 14, 2024 Thanks so much MarkMc! Really appreciate your help. I am also making the time to learn more about making custom cabinets in CA 8 hours ago, MarkMc said: Yes you should BUT calling it a custom cabinet door is a bit oversimplified. More like 3 custom doors and some tricky cabinet manipulation. At least the only way I know. Parts from a recent one with an adjustment close to yours I think, sides may be a little different. Open everything in the attached plan, every tab, then try on your own. ' valet cab.zip 703.68 kB · 3 downloads Link to comment Share on other sites More sharing options...
