DG1949 Posted May 5, 2024 Share Posted May 5, 2024 Can't figure out what I'm doing wrong. Everything is set to auto-rebuild, and to use Framing Reference. This is the second floor framing, and the roof is on top of the 2nd floor. As you see, the joists are offset by 3/4". The wall studs below them are where they should be. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted May 5, 2024 Solution Share Posted May 5, 2024 As far as I can tell, Chief has always centered the wall studs and then aligned the sides of the joists. Not sure why though and I always just move them over manually when I actually need to. Link to comment Share on other sites More sharing options...
DG1949 Posted May 6, 2024 Author Share Posted May 6, 2024 Thanks, DB. Link to comment Share on other sites More sharing options...
