HOW TO DO A REVEAL BETWEEN BASE BOART AND THE SHEET ROCK?
Sandor09
Good morning from Portugal to all!
I am doing my first steps in the Chief Architect and I am trying to learn as much as I can.
Now I am facing with the following doubt:
HOW TO DO A REVEAL BETWEEN BASE BOARD AND THE SHEET ROCK?
Please see my attached image for better understanding.
I will also need for ceiling but the concept should be the same.
Thank you so much in advance!
The easiest way that I have found is to use room moldings. Easy to apply to a whole floor, a room and/or eliminate on walls as desired with CA's room molding control. I used the air gap material at first but prefer the look of just black color. Use moldings set 1/32 to 1/16 proud to inside of wall face to avoid 3D "Z-fighting".
Thank you so much dear Charles,
I will try your option tomorrow because I spent my entire day trying to find the solution :) but with no success.
And the same type of reveal around the ceiling? Is it possible?
thanks once again!
