HouseJackBuilt Posted April 8, 2024 Share Posted April 8, 2024 How do I keep my wall heights from reverting back to default? When I build a garage with 12ft high walls, then when I build the 2nd floor - it brings my first floor garage walls down to default 9ft walls. I had this problem when I did an addition. The walls in the original house were 6ft high, when I worked on another part it brought it back to default. I was unable to fix it then too. I'm sure it is something stupid. Thanks, Jack Link to comment Share on other sites More sharing options...
HouseJackBuilt Posted April 8, 2024 Author Share Posted April 8, 2024 For further information I am running a X15. Link to comment Share on other sites More sharing options...
Solution TeaTime Posted April 8, 2024 Solution Share Posted April 8, 2024 37 minutes ago, HouseJackBuilt said: then when I build the 2nd floor When you hit Build New Floor, take a look at the options, there's one for floor heights and one for roofs. Link to comment Share on other sites More sharing options...
SNestor Posted April 8, 2024 Share Posted April 8, 2024 Wall heights are controlled by the height specified in the room...or, floor defaults. Rooms will derive their height from the "floor default" height. Link to comment Share on other sites More sharing options...
