KnotSquare Posted April 1, 2024 Share Posted April 1, 2024 Hello Ladies and Gentlemen, Likely I have to use my topography lines and the property boundary to place the design back on the 20-acre lot as they want to evaluate it against an existing structure I am hoping that someone may know just how to move an entire 3-story, custom framed plan to a site, or more likely, a 20-ac site with well, septic, propane, and a pole barn with driveway from the road to more than 1/3rd into the property to the house plan. If I just have to rebuild the lot around the house, I have that suspicion. I have been setting all the elements I can think of to "Absolute" height as previous attempts have lost entire walls and partial roof areas that were custom framed and my Architectural Block columns showed up at a variety of heights. Should anyone have some pointers, please offer them up. Thank you, Mark Link to comment Share on other sites More sharing options...
VisualDandD Posted April 1, 2024 Share Posted April 1, 2024 Open a 3d view of home. Make sure to turn OFF terrain so just the house and foundation is shown. Convert that into a symbol. Next, build your site model and then set your home into said model. Depending on the plan/foundation, sometimes I cut a hole in the terrain using a copy of the orignal home perimeter, but if not a basement, or you are only looking at views outside home, it should not matter. Link to comment Share on other sites More sharing options...
Mark3D Posted April 2, 2024 Share Posted April 2, 2024 Check out the edit area tools in the edit menu Link to comment Share on other sites More sharing options...
