Adding Items To Soffit
dmbarbee
I am using x15 and have drawn a soffit that covers the entire kitchen ceiling. I wanted to add a ventilation register on the soffit, but was not able to place it when I tried. The register placed on a regular wall, but not on the soffit.
Is it possible to place items to soffits?
I also attempted using the 3D Solid Tools feature, but I ran into the same problem, I was not able to place the vent.
Attached are two images, one of my design, and the other is the inspiration.
Quote
Yes, you can add electrical objects to soffits.  So you could convert your vent into a wall mounted electrical object and then it would work.  Not sure it's really worth the trouble though because if your vent is just a fixture you should be able to just place it in the plan and bump it against the soffit.
