ovnttim Posted March 28, 2024 Share Posted March 28, 2024 I'm using Chief Architect X12. I have a Foundation Plan and Basement Plan every time I make a call out to one plan it's showing up on the other plan. I know it's due to my Layer Set settings but not sure how to unlink the two. I have a Layer display option for each one one for Foundation and one for Basement can someone tell me what I'm doing wrong. Thanks. Link to comment Share on other sites More sharing options...
TeaTime Posted March 28, 2024 Share Posted March 28, 2024 If I recall correctly X12 worked the same as X15 does in this regard. You need to set the Layer Set for the saved view you're in. Link to comment Share on other sites More sharing options...
JLU_Design Posted March 29, 2024 Share Posted March 29, 2024 Default Sets This is super powerful once you can get your mind wrapped around it. https://www.chiefarchitect.com/videos/watch/240/understanding-default-sets.html I think the most important thing is to have the following specific layers for each default set. A specific CAD layer for each Default Set: A specific Dimension layer for each Default Set: A specific Revision Cloud layer for each Default Set: As you can see I don't have a specific revision cloud layer for all my default sets. Some of them share Revision Clouds, General. A specific Text layer for each Default Set: I've thought that it would be nice to have a wizard to create all of the important parts to a new default set because it's a good bit of stuff to try to remember to check when setting up a new default set. 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 30, 2024 Share Posted March 30, 2024 On 3/28/2024 at 9:14 PM, JLU_Design said: Default Sets This is super powerful once you can get your mind wrapped around it. More powerful if you’re using default sets via Saved Plan Views. Link to comment Share on other sites More sharing options...
