amddrafting Posted March 15, 2024 Share Posted March 15, 2024 Good morning folks. Since we are getting into more commercial work it is more common for us to display room numbers on plans. I noticed that the schedule has an option to show room numbers but there is no macro for us to be able to include room numbers to display in a text box or even in the room label that I can find. Is this a possibility or are we stuck manually entering in room numbers? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 15, 2024 Share Posted March 15, 2024 I have a set of macros to do this in RTB's. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 15, 2024 Share Posted March 15, 2024 The price for my "Room Macros" package is $75.00 It actually includes 35 macros covering almost anything that is related to rooms. room_areas - accumulates room areas to a $Global Hash - displays "" - needs to be in each room label room_ceiling_finish_layers room_ceiling_height_ft room_ceiling_height_ftin room_ceiling_height_in room_ceiling_structure_layers room_conditioned_existing_list room_conditioned_existing_total room_conditioned_floor_names_areas room_conditioned_floor_total room_conditioned_new_list room_conditioned_new_total room_dimensions room_dimensions_secondary room_floor_finish_layers room_floor_structure_layers room_internal_area room_internal_area_secondary room_label room_living_areas room_moldings room_name room_num_baths room_num_beds room_num_name - master room label for all rooms. room_number room_open_below_areas room_perimeter room_reqd_window_area room_standard_area room_standard_area_secondary room_total_building room_unconditioned_spaces_all_Floors room_unconditioned_total room_volume room_volume_secondary room_wall_coverings room_window_reqd Most of the above can be used in a RTB placed in a room - as well in a Room Schedule. I include a Library Object (RTB) with several of the above macros as an example. Payment can be made to Paypal Account chriscoll@dslextreme.com or Venmode Account joe.carrick@dslextreme.com Link to comment Share on other sites More sharing options...
amddrafting Posted March 15, 2024 Author Share Posted March 15, 2024 On 3/15/2024 at 4:40 PM, solver said: https://chieftalk.chiefarchitect.com/search/?&q="room numbers"&search_and_or=or Expand Funny, I searched "Room Numbers" and got none of these results otherwise I wouldn't have posted it Link to comment Share on other sites More sharing options...
robdyck Posted March 15, 2024 Share Posted March 15, 2024 When I need to do this, I use a customized Text Note. I set a new note type and use a schedule that includes only the note used for Room Numbering. You will need to manually place the notes and manually organize them, but at least you can't make mistakes regarding the scheduling. Using the Object Information Panel, you can add the Global macros that are available for rooms in the provided fields, or in custom fields. My preferred note shape for this is a 'capsule'. Link to comment Share on other sites More sharing options...
