Can I lock Auto Pole Dimensions?
mlyric44
Is there a way to lock the Auto Story Pole Dimensions? I find that I'll do them, then I can do something as small as reverse a window and it gets rid of the dimensions from the T.O.P. and down. It's really annoying because I'm constantly having to go back and redo it.
Thanks in advance.
All you'd have to do is cut/paste the story pole dimension (ctrl-x, ctr-alt-v). This will add point markers at each dimension extension. The elevations will remain as noted but they won't be locating the noted elevations. If you don't want to see those point markers in your elevation or section view, simply select them all and make them really small / place them in the back of the drawing order.
This method requires a bit of habit / memory so that you know / remember your process.
