Imported PDF to Lines
ehumble
What are you trying to do? If you are making a floor plan, just trace the PDF after importing and scaling. It will be faster than cleaning up CADD lines. If they are CADD details, that is another story and case dependent based on what you have for images.
I need to be able to use the PDF as is but clean it up to delete notes and dimensions for furniture layouts. I was hoping there was a way to do this without redrawing it because that is time consuming. Importing a CAD drawing works great for this but we mostly get PDF's and don't always have access to the CAD drawings so wondering if there is a way to easily clean up a PDF.
  • 1 year later...
Yesterday I spent the whole day looking for a similar topic. Thanks for the advice - converting to DWG helped. By the way, I found a great online converter PDF Guru https://www.pinterest.com/pdf_guru/ and it handles this task perfectly. Honestly, I’ve always been skeptical about online tools, but after trying this one, I changed my mind. It turned out to be really simple and high-quality.
Edited by bintrat
