cbucks Posted March 4, 2024 Share Posted March 4, 2024 Good day is there a way I can reset working plan view etc back to default without reinstalling? Link to comment Share on other sites More sharing options...
MarkMc Posted March 4, 2024 Share Posted March 4, 2024 Open an unmodified template, hopefully the residential has not been fooled with. Save as "something". In your plan- file, import saved plan views. Select working from the DBX and check replace. Though to me the purpose of the working plan is that it can be whatever I need at the moment and NEVER ever gets sent to layout. Making the default moot. The other plan views however need to be dealt with judiciously. Link to comment Share on other sites More sharing options...
ValleyGuy Posted March 5, 2024 Share Posted March 5, 2024 7 hours ago, cbucks said: Good day is there a way I can reset working plan view etc back to default without reinstalling? You may also be interested in checking off the 'Never Save' in the plan view specifications if you don't want it to change again on you once you get it back to the way you had it. 'Prompt to Save' at least asks you after you changed something, and 'Always Save' is the sneaky little invisible guy that kept on messing up all my plan views. Link to comment Share on other sites More sharing options...
