Landing not leveled
Omnidesign
11 hours ago, Omnidesign said:
Hi Doug,
ok, thanks, didn't know we could post the file! First time user.
The file is bigger than 14MB!
Backup the plan file as a zip (right from the CA save menu)  It will be a lot less than 14m then.
  • Like 2
You might want to use a room with a floor platform instead of a landing in this case.  In general, I use landings in between stair sections and then floor platforms for where the stair starts or ends.  Regardless, if you need to move a landing up or down you can open the dialog and set the landing height to whatever you want.
For more detailed help, you should probably post the plan.
Untitled 1.zip
Hi Doug,
Thank you so much for taking the time to answer and solve my problem, much appreciated!
Just to put you in context, it's a townhouse remodeling, a complete renovation of the 2nd floor.
I'm transitioning from AutoCAD to Chief! It's quite a challenge but a good one I think!
