msmith964 Posted February 23, 2024 Share Posted February 23, 2024 I have never been able to get vanity lights to look light actual lights. This is a perfect example. The bulb material is White Lighting. I have tried every level of lumens and if I go too bright it washes out the glass. If I go too low, it doesn't show at all. I also have lights set at each bulb at 200 lumens but they don't show up as individual lights in the bulbs. How do you do it?? I have attached a photo. It is a horrible rendering because of the lighting. I use PBR renders. FYI, I have turned off the back walls of the room so I can see the room. I am using CA Pro X15. I have attached the pic and the plan. Help! Thanks! proposed bath.zip Link to comment Share on other sites More sharing options...
MarkMc Posted February 24, 2024 Share Posted February 24, 2024 3 hours ago, msmith964 said: How do you do it?? Not sure what you want them to look like. I fiddled a bit guessing at that. Sometimes it's changing to spots, sometimes it's a mix of point and spot. Changing backdrop can help if it allows some added light without bringing in too much color. Adjusting materials is likely key. For most of these I lowered the changed the emissive of the light bulbs, also changed the shade material. I'm not sure which of those materials will come through but plan with a couple of lights included, hopefully I managed to include the materials (but was just messing around so not as careful as I should have been) Oh and FWIW what I got from your plan looked better than the image you posted before I did anything. Not sure why. Original Option on the bright side Emphasis on bulbs Changed backdrop and increase light from it Looks as if I have to post plan after this. Link to comment Share on other sites More sharing options...
MarkMc Posted February 24, 2024 Share Posted February 24, 2024 Plan file Bath pt lights.zip Link to comment Share on other sites More sharing options...
ericepv Posted February 24, 2024 Share Posted February 24, 2024 I agree with Mark, adjusting your shade material and emissive value are the key. I also like to add a light source to enhance the scene. I made the following changes to your plan: Changed shade material to Milk Glass (General material, Emissive set at 50) Changed all 3 lights from point to spot (tilt -90, intensity 200) Finally, I added a light source (point, intensity 200) positioned at the center of your fixture (set to a 72" elevation to minimize ceiling wash) and with 'Cast Shadows' switched on Here's what I got... 1 Link to comment Share on other sites More sharing options...
msmith964 Posted February 24, 2024 Author Share Posted February 24, 2024 Thank you both. Those are great solutions! Appreciate your input. Link to comment Share on other sites More sharing options...
