LotzCC Posted February 9, 2024 Share Posted February 9, 2024 I am adding a screened patio with screen panel windows and a screen door and have selected the same screen material for both. As you can see on the attached image, the screen material shows differently on the door with the material image texture showing much larger. I am also attaching my CA file. Thompson 1.1.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted February 11, 2024 Share Posted February 11, 2024 On 2/9/2024 at 10:26 AM, LotzCC said: As you can see on the attached image, the screen material shows differently on the door with the material image texture showing much larger In this case it is that particular Door you chose from the Library (a Bug) switch it to the default Glass Panel door and the Materials show the same however, the "screen" you chose is actually a fabric, not Window Screen Material , have a look at the plan I attached, it has 2 different ones you can play with and save to your Library. Ooops looks like you have X14 so my plan might not be openable unless you have X15 and need to update your Sig.? Mick. X15 Plan only : Thompson1.1_MHD.plan Link to comment Share on other sites More sharing options...
LotzCC Posted February 12, 2024 Author Share Posted February 12, 2024 Thanks Kbird1, I am using X15 and can open your file. You are correct in pointing out my screen material is using a fabric texture. I was not able to find a screen material in any of the Chief catalogs and created my own screen using a fabric texture as directed by a one of the how to make a screened patio videos. It appears that your screen material that uses the mesh texture is scaling the same when applied to the door and the screen panels. This is not the case for the screen material that I was using. Seems like if the same material is applied to any objects in the plan, it should display the same no matter where it is used. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 12, 2024 Share Posted February 12, 2024 7 hours ago, LotzCC said: Thanks Kbird1, I am using X15 and can open your file. You are correct in pointing out my screen material is using a fabric texture. I was not able to find a screen material in any of the Chief catalogs and created my own screen using a fabric texture as directed by a one of the how to make a screened patio videos. It appears that your screen material that uses the mesh texture is scaling the same when applied to the door and the screen panels. This is not the case for the screen material that I was using. Seems like if the same material is applied to any objects in the plan, it should display the same no matter where it is used. As I mentioned there is a bug in that particular door you were using from the Library it seems. There are 2 different mesh materials in the Plan now, the one on the front is different than the side with the door, but it maybe you have found a wider bug too, if so it should be reported. M. Link to comment Share on other sites More sharing options...
Solution SNestor Posted February 14, 2024 Solution Share Posted February 14, 2024 I agree with Mick...there is some issue with the door you placed. So...just change the door to the standard glass panel door...and change the material to screen. Also...you should edit the "pattern" in the material so it looks correct in Vector view. I've attached a couple screen clips. Link to comment Share on other sites More sharing options...
LotzCC Posted February 14, 2024 Author Share Posted February 14, 2024 I missed the comment about the door having a bug, but now I understand. The screen shots of the pattern settings are also very helpful. Thanks to all! Link to comment Share on other sites More sharing options...
