BuilderP Posted February 5, 2024 Share Posted February 5, 2024 I am mocking up a space I am adding to my home. The existing home is not shown in this plan version, just the addition. I am having trouble getting the deck framing correct. When I draw the deck perimeter using the straight deck rail tool, Chief automatically generates the framing but runs the deck joists and planks all the way under the sill plate for the exterior walls of my living space. Why? I have tried changing various default framing settings but have not found the correct one. Plan file attached in zipped folder. Any help would be greatly appreciated. Deck Problem.zip Link to comment Share on other sites More sharing options...
DBCooper Posted February 5, 2024 Share Posted February 5, 2024 Your zip file is empty. This means that you probably had the plan open when you tried to make it. Link to comment Share on other sites More sharing options...
BuilderP Posted February 5, 2024 Author Share Posted February 5, 2024 Oops - yes, you're correct. Didn't know I had to close the file first! Here it is.... Deck Problem.zip Link to comment Share on other sites More sharing options...
Solution SNestor Posted February 6, 2024 Solution Share Posted February 6, 2024 @BuilderP Open the room just to the north of the lower deck...the room with the kitchen. In this room...change the "slab pour" number back to #1. That'll fix it. Link to comment Share on other sites More sharing options...
BuilderP Posted February 6, 2024 Author Share Posted February 6, 2024 55 minutes ago, SNestor said: @BuilderP Open the room just to the north of the lower deck...the room with the kitchen. In this room...change the "slab pour" number back to #1. That'll fix it. Thank you! I never would've found that solution. I honestly don't understand what the "slab pour" number does or how it got set to a different number for that room. Thank you for your help. This was driving me bananas. Link to comment Share on other sites More sharing options...
