ChiefUserConnorC Posted February 4 Share Posted February 4 I have a plat and specific lot boundary (4 sides) that I want to replicate. I want 3 of the 4 sides to be straight lines, not angled. So, it seems I need to adjust the north pointer to show the correct bearings but can’t get precise enough. How do I keep the 3 boundary lines square but show exactly the same bearings as on the plat. Lot 16 is the one I’m re-creating. Link to comment Share on other sites More sharing options...
glennw Posted February 5 Share Posted February 5 Without knowing what you are doing..... Open the Line Style dbx for the north pointer. Down the bottom, click Number Style and select Quadrant Bearing. Open General Cad Defaults and check Quadrant Bearing. Link to comment Share on other sites More sharing options...
scottharris Posted February 5 Share Posted February 5 See if this terrain webinar video helps @ ~30:20 Link to comment Share on other sites More sharing options...
ChiefUserConnorC Posted February 5 Author Share Posted February 5 Very good. I figured it out thanks to both of your help! Thank you. Link to comment Share on other sites More sharing options...
