CAUserAlicia Posted January 31, 2024 Share Posted January 31, 2024 Hi Everyone, I have two elevation views in the standard rendering technique. I like this rendering technique because it shows the finishes better than the vector view. Vector view shows cabinets as a solid color whereas the standard view displays the wood texture. The Stove Wall Elevation is what I want the sink kitchen wall elevation to look like. Although for some reason it is displaying darker and I have no idea why that is. Does anyone know why it is doing this and how to fix it? I tried playing with the sunlight and turning up the interior ambient lighting in the standard rendering defaults and no changes. Also tried changing the materials to have 0% shadows and no change. It's a galley kitchen, I have attached the elevations to show the difference and the floor plan as a reference. Hoping someone can help. Kind Regards, Alicia Link to comment Share on other sites More sharing options...
robdyck Posted January 31, 2024 Share Posted January 31, 2024 What version are you using? And if you attach the plan fie, I'll trouble shoot this. Link to comment Share on other sites More sharing options...
Gawdzira Posted January 31, 2024 Share Posted January 31, 2024 Try turning off the sun. Link to comment Share on other sites More sharing options...
CAUserAlicia Posted January 31, 2024 Author Share Posted January 31, 2024 Chief Architect Premier X14. I got it figured out! I just needed to check sun follows camera and it worked. Now all my elevations match. I have attached a photo of where I made the change for the next person that may run into this. I opened up the elevation camera and than in the Camera dialog under lighting I clicked adjust sunlight (Sunlight was already checked off) and than I checked sun follows camera and clicked ok. That worked perfectly. Thanks for all the responses. Have a great day! Kind Regards, Alicia Link to comment Share on other sites More sharing options...
