cbucks Posted January 31, 2024 Share Posted January 31, 2024 I am having a weird problem where terrain is going through a floor in 3D not sure how to fix? My cars are sinking Link to comment Share on other sites More sharing options...
rlackore Posted January 31, 2024 Share Posted January 31, 2024 It may be as simple as this: Link to comment Share on other sites More sharing options...
DBCooper Posted January 31, 2024 Share Posted January 31, 2024 Could be a few other things as well, such as your rooms not being connected/defined correctly or your terrain is on the wrong floor. That is why it is usually best to post the plan file when you have problems like this. Also, just as an FYI, if your auto terrain hole for the building does not follow the walls the way you want it to, you can convert it into a manual hole and then edit the shape. Look up the help for "make terrain hole around building". You can even just create manual holes if you need to. Link to comment Share on other sites More sharing options...
