DRAWCO Posted January 29, 2024 Share Posted January 29, 2024 How do I make the footing 18" below gradw? Link to comment Share on other sites More sharing options...
TeaTime Posted January 29, 2024 Share Posted January 29, 2024 Check out Walls with Footings + Slab at Top of Stem Wall You can edit the walls to behave as your slab footing. Link to comment Share on other sites More sharing options...
GeneDavis Posted January 29, 2024 Share Posted January 29, 2024 Thicken the slab edges to 24" total depth. The edge footing will have a 20" height if your slab spec is 4" thickness. I put a 20 x 20 bevel on the inside faces, for a 24" haunch. Sort of like what is attached? This one's a 16, so the x by y on the haunch is 12 x 12. Link to comment Share on other sites More sharing options...
