Floor Label In Layout
marklcc
How do you change the default floor label from 1st floor or 2nd floor?
I want to set a default label " First Floor Plan"
I know I can change them in layout with a custom label, but you should be able to set them before they go to layout.
You can't edit floor plan information in the project browser.
Anyone have a solution?
Mark,
You could use a macro for the Layout Box Label to construct the desired name.  Basically the macro would check the 1st character of automatic_label and if its 1 then return First Floor Plan, if it's 2 then return Second Floor Plan, etc.  The macro could be "brute force" or it could be done with a bit more elegant programming.
Chief really should allow us to change the name of the Floor Plans in the Project Browser.
