VirtualDesigns Posted January 11, 2024 Share Posted January 11, 2024 Where is the option to prevent dimensions from automatically flipping orientation on a rotated view? Thanks Chris Link to comment Share on other sites More sharing options...
robdyck Posted January 11, 2024 Share Posted January 11, 2024 Dimension Defaults > Text Style > Options... Link to comment Share on other sites More sharing options...
TeaTime Posted January 11, 2024 Share Posted January 11, 2024 1 minute ago, robdyck said: Dimension Defaults > Text Style > Options... I don't believe that affects Dimensions though, only normal text like labels and such. I think Dimensions always face "down" and "right". I'm curious why the view is rotated that direction? All text is Upside Down with respect to the title block. Link to comment Share on other sites More sharing options...
robdyck Posted January 11, 2024 Share Posted January 11, 2024 Just now, TeaTime said: I don't believe that affects Dimensions though, I kinda thought that but couldn't remember for sure. Also, I'm not sure if the OP rotated the view in layout or rotated the Plan View or if there is a difference between those two methods. My own preference would always be that all vertically oriented text is read from the right with a few minor logical exceptions. In the OP's picture, I'd suggest the dimension is correct and the other plan view text appears to be in need of adjustment. I've only ever rotated a plan once and text adjustment was a pain. After that process I preferred to use the Edit Area tool if I run into a situation where the plan has developed in such a way that a rotation is suitable. Link to comment Share on other sites More sharing options...
VirtualDesigns Posted January 11, 2024 Author Share Posted January 11, 2024 I will just resize the sheet larger to fit the plan vertically instead of rotating it to fit. Thanks for the feedback. Link to comment Share on other sites More sharing options...
