rcmcdougle Posted January 2, 2024 Share Posted January 2, 2024 This is a partial plan of an apartment building with12 apartments per floor. My client wants to combine 3 of the apartments into one dwelling. This "As Built" was traced over a PDF referencing the several different wall types. It seems that I have properly closed walls but no rooms are differentiated. If I click in any room, the whole interior is selected. Why is this blowing up? BCD_asBuilt.plan Link to comment Share on other sites More sharing options...
Solution Designers_Ink Posted January 2, 2024 Solution Share Posted January 2, 2024 You have at least one wall that is marked "No Room Definition" in the wall DBX. Just select all of the walls and open the dialog. There will be a dash next to that setting. Click it until the box is empty, and you should be good. 1 Link to comment Share on other sites More sharing options...
5FT-20Designs Posted January 2, 2024 Share Posted January 2, 2024 Your wall have have "No Room Definition". Uncheck abnd you should be able to define your rooms. Link to comment Share on other sites More sharing options...
rcmcdougle Posted January 2, 2024 Author Share Posted January 2, 2024 Is there a way to do this for all the walls in the plan? I have no idea how those walls were created with No Room Definition but... Thanks for your help guys. Link to comment Share on other sites More sharing options...
Designers_Ink Posted January 2, 2024 Share Posted January 2, 2024 Just now, rcmcdougle said: Is there a way to do this for all the walls in the plan? I have no idea how those walls were created with No Room Definition but... Thanks for your help guys. Select one wall, the click on the Select Similar Objects button. It looks like a cross with 4 dots and a mouse arrow. Mine is on the bottom toolbar. Then just draw a square around your whole model. It will only select the walls. Then click the Open Object (door) button to open the dialog box. 1 Link to comment Share on other sites More sharing options...
