Columns placement on porch
Opondo
Go to solution Solved by ericepv,
  • Solution
Select your rail then:
  • Click on 'Newels/Balusters'
  • In the 'Newels/Posts' section, enter the desired width and spacing
  • In the 'Type' section, click on 'Library' and navigate to your chosen column
  • Click on  'Rail Style' from the menu and go to the 'Start /End Posts' section to determine where on the rail you want a column
