ChiefChrissy Posted December 5, 2023 Share Posted December 5, 2023 How can I get the wood plank floor material pattern to be visible in my finish plan? The material is correct in 3d view and in the room specification dialog box but I want it to show up on the floor plan view. Link to comment Share on other sites More sharing options...
ChiefChrissy Posted December 5, 2023 Author Share Posted December 5, 2023 UPDATE TO THIS QUESTION: apparently my futzing with it solved the problem for a few of the layer sets but not the one I need it in. Now my flooring pattern shows up in my ceiling and electical layer sets but not the finish layer set. and attempts to fix it in tools/ display settings are not fixing it. grrrr... any advice? Link to comment Share on other sites More sharing options...
DBCooper Posted December 5, 2023 Share Posted December 5, 2023 As far as I know, you can't display the room's floor material in a plan view, only in a camera view. You can display the room's "fill style" and this will show or hide based on the layer called "Rooms". Link to comment Share on other sites More sharing options...
Michael_Gia Posted December 5, 2023 Share Posted December 5, 2023 2 hours ago, ChiefChrissy said: How can I get the wood plank floor material pattern to be visible in my finish plan? The material is correct in 3d view and in the room specification dialog box but I want it to show up on the floor plan view. You can set a fill pattern in plan view as DBCooper mentioned. I usually use these settings... To get this effect for wood flooring... the background color is Mocha with 80% transparency. Link to comment Share on other sites More sharing options...
