Cabinets: Need to see callout in elevation when cabinet is behind a 3D solid
GeneDavis
Go to solution Solved by DBCooper,
I tried my best to do a good description of the situation.  I have a refrigerator cabinet drawn with the partition tool used for the plywood panel sides, and they are specified to be tallied in the cabinet schedule.  They are there in the schedule, and the callouts display in the plan view.  OK so far.
I do these fridge cabs routinely as 3/4 plywood partitions to which is affixed a 3/4" x 1 1/2" stile on front edges.  One of the images attached shows the subassembly, highlighted, as I selected both the partition (plan view R side fridge) and the front stile.
In elevation view, the callouts do not show, because the scheduled "cabinet," the partition, is hidden by the front stile.  If I move the stile out so to be able to see the partition, the callout shows.  I want it shown with the stile in place.  The screencap of the elevation shows the right side panel, "exploded" with the stile moved away, and displaying the panel's callout.  But no callout is there on the left.
What is the workaround, please?
