Manual Porch Roof
Jarenand
Go to solution Solved by TeaTime,
You'll want to raise the height of the upper roof planes - or lower the front one in order to create that separation we see in the photo.
Don't use a Hole in Roof for this, just break the edge and pull it back. This should be done on both roof planes, the photo shows the lower shed is split into two.
Pulling a smaller edge through the entire plane will split it.
image.png.45bcc12e9dc87e36a2230cecc7208dcb.png > image.thumb.png.3e0ceadb11486e68bccccdbf600f0d7c.png
For the upper roof plane, break it in three places to create a triangular shape in order to properly Join the roof planes.
Lastly, the new gable roof planes are up on Floor A, not a problem per se but it makes it harder to work with them all.
Move them down to Floor 1 and Join them all up.
  • Solution
9 minutes ago, Jarenand said:
I am curious though as to why I have the gap you can see.
That gap is common in exterior type rooms. Its the roof ceiling surface being placed under the full rafter depth, you don't normally see that because there's usually a wall there covering it up. If those roof plane's stud thickness can be reduced then that'll take care of it. But a quick fix is actually in the porch room specification. Under the Roof section there's an option to Use Soffit Surface for Ceiling. This reduces the rafters over the entire room, instead of just at the eaves.
