bocamnz Posted November 30, 2023 Share Posted November 30, 2023 Have just migrated a plan to a new computer as a zip file all seemed to be ok until going to 3D views of exterior. Everything was BLACK walls ,roof, terrain . Obviously done something wrong but no idea what. Appreciate any help. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 30, 2023 Share Posted November 30, 2023 Unfortunate situation for sure but way too many variables to troubleshoot. Sounds like perhaps a rendering issue so maybe start with posting the specifications of the new computer. We would all assume the new computer would have better specifications that the old one that was working fine but perhaps you chose a different class of machine ? Also good to know what version of the software you are using. Hopefully the .zip file was a backup copy that contains all the materials but even if not defaults should have been substituted. If all of the above checks out we may need to have a look at your plan file. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 30, 2023 Share Posted November 30, 2023 15 hours ago, Chopsaw said: Sounds like perhaps a rendering issue Too me as well so it would be good if you did your Sig with your system details and version of Chief, (See CS and mine) as it sounds like your Videocard may not be upto a newer version of Chief. ie if you went from X12 to X15..... Link to comment Share on other sites More sharing options...
