Steve_Nyhof Posted November 22, 2023 Share Posted November 22, 2023 How to Rotate an object into specific alignment https://myplan.stevenyhofdesigns.com/6quwn9pm Link to comment Share on other sites More sharing options...
BenPalmer Posted November 22, 2023 Share Posted November 22, 2023 "Rotate entire polyline" select the object you want to rotate double click the 'make parallel' tool select 'rotate entire polyline' in dbx that pops up parallel to the selected line Be aware that you are now in that parallel mode, so you will need to change it back when you need to...in the same way. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 22, 2023 Author Share Posted November 22, 2023 Wow! I think I need to spend some time just double clicking on the toolbars. That has more than once giving the answer. I should have asked this question 3 years ago Thank you so much!! 1 Link to comment Share on other sites More sharing options...
TeaTime Posted November 22, 2023 Share Posted November 22, 2023 FWIW Most toolbar icons are either an on/off toggle, or they immediately perform some action (making the toolbar change), or they activate a new set of tools (making the toolbar change). There are only two icons I can think of off the top of my head that have some special double click behavior, Make Parallel and Pan. Both of which don't immediately do anything when you click the button since they rely on user input in the view screen, and both have a secret double-click behavior. There may be others but I've not come across them. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 22, 2023 Author Share Posted November 22, 2023 On 11/22/2023 at 11:22 PM, TeaTime said: FWIW Most toolbar icons are either an on/off toggle, or they immediately perform some action (making the toolbar change), or they activate a new set of tools (making the toolbar change). There are only two icons I can think of off the top of my head that have some special double click behavior, Make Parallel and Pan. Both of which don't immediately do anything when you click the button since they rely on user input in the view screen, and both have a secret double-click behavior. There may be others but I've not come across them. Expand Thank you. I just went through a number of them and at least found some older buttons I have not used and even set hotkeys to. So was a good exercise to get to know my toolbars again. 1 Link to comment Share on other sites More sharing options...
