Larry_Sweeney Posted November 21, 2023 Share Posted November 21, 2023 When adding a frieze under the roof return, what determines the length of the frieze from the end of the return? There should be a way other than changing the molding line manually. It's a real PITA when you have a house with a couple dozen returns. Then at times when you move the frieze molding line the molding ends up anywhere but where you wanted it, which after this happening it takes more than two cups of coffee to settle a person back down. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 21, 2023 Share Posted November 21, 2023 5 minutes ago, Larry_Sweeney said: which after this happening it takes more than two cups of coffee to settle a person back down. Take a Zanax 1 Link to comment Share on other sites More sharing options...
