Exterior wall stud showing
MaggieTS
Go to solution Solved by GeneDavis,
I am having issues getting my exterior walls to show studs. I have already ensured that the structure of the walls includes the framing and have turned on the correct layers but no dice. I am trying to show it as an unfinished interior wall so I have deleted the drywall layer as well but the drywall still shows in my 3D view. All my other framing (trusses, exterior rafters, rim boards, etc.) are showing up but the walls are remaining blank.
Thanks!
Maggie (Premier X14)
image.thumb.png.4013e4eb0e472d20b808df6c10b3db38.png image.thumb.png.981d298ecbe28ff525b8c10982699352.pngimage.thumb.png.398674e6e27c08ca3b052d801c3ae5f5.pngimage.thumb.png.347f8cb1a6da8cb603eb4d10ac045f1c.png
It's hard to say for sure without seeing the plan and it's very hard to make out in the image, but it kind of looks like in the cross section that the inner line of the walls is thicker than a single line. You're editing the Siding-6_2 wall, are you sure that those walls are Siding-6_2?
Post the plan if you're still stuck.
