JiAngelo Posted February 23, 2015 Share Posted February 23, 2015 Regardless of the PPI settings, 72, 144, 288, 360 - all my saved image files are identical in size. I've attached 3 sets of both ISO-FrontRight.jpg & ISO-FrontRight.png and LVL1.png saved in varying resolutions. I can't find the difference. Additionally, this new "Export Picture" dialog opens with some default settings. Change them, and it re-opens with the default settings again - yet there is no where to set these values in the "Defaults" or "Preferences" dialog. In X6, I clicked "Export Picture" icon and just started typing the filename in the "Export Picture File" Dialog, hit enter and voila - done. In X7, I click "Export Picture" icon and either A) FIND "Export Picture" Dialog with my mouse and click OK, then start typing the filename ... OR hit the enter key, then start typing the filename... Extra steps to accomplish the same task is not an improvement. Please move this to the "Defaults" or "Preferences" dialog - or give me a separate icon that just gets me to the filename dialog. Let me know if I'm simply doing it wrong? Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 23, 2015 Share Posted February 23, 2015 My guess is that it has to do with vector view versus rendered view. Probably not much can be done with vector line drawing. Link to comment Share on other sites More sharing options...
AriseDesign Posted February 23, 2015 Share Posted February 23, 2015 What pixel size did you specify? I had to turn mine up to like 9600 pixels per inch to notice a difference Link to comment Share on other sites More sharing options...
JiAngelo Posted February 23, 2015 Author Share Posted February 23, 2015 Thanks for the responses. I've tried exporting rendered, perspective, etc.. no change. Also tried upping the DPI to 9600, no change in filesize or appearance. I've tried increasing the dimensions and weird things started happening above 3,000 width. Link to comment Share on other sites More sharing options...
MarkMc Posted February 23, 2015 Share Posted February 23, 2015 Change the "dimensions" to units first, then change the dpi. Picture size based on pixels will simply change the unit size to suit the dpi. First I tried that and changed dpi to 1200 and got a warning regarding file size. Here is untitled 1-3, 75, 150 and 300 dpi. Link to comment Share on other sites More sharing options...
