2-story floor to ceiling windows
DanoCAD
I have this two-story stair well with floor to ceiling windows on two adjacent corner walls and one of the windows has this piece of what appears to be subflooring showing and I cant figure out why it is there.   The other window does not have it . . . it is on a "flooring surface" layer . .
The second story walls are lined up right on the money.   Yet I still see this piece of flooring running right through only one of the windows . . .
I had the same issue a while back Dano.
What you need to do is open the room dbx of that "open below" area of the floor above that landing.  Go to the structure tab and edit the floor structure, by deleting the materials.  Once deleted, your Floor Structure will be 0".  Hit Ok, then that OSB will disappear.
Hope this helps.
I am assuming your using X15.  Regardless, should work with any prev release.
