DanoCAD Posted October 29, 2023 Share Posted October 29, 2023 I have this two-story stair well with floor to ceiling windows on two adjacent corner walls and one of the windows has this piece of what appears to be subflooring showing and I cant figure out why it is there. The other window does not have it . . . it is on a "flooring surface" layer . . The second story walls are lined up right on the money. Yet I still see this piece of flooring running right through only one of the windows . . . Link to comment Share on other sites More sharing options...
ericepv Posted October 29, 2023 Share Posted October 29, 2023 Have you set the room type for the stairwell as 'Open Below'? Link to comment Share on other sites More sharing options...
mtldesigns Posted October 30, 2023 Share Posted October 30, 2023 7 hours ago, DanoCAD said: what appears to be subflooring showing and I cant figure out why it is there I had the same issue a while back Dano. What you need to do is open the room dbx of that "open below" area of the floor above that landing. Go to the structure tab and edit the floor structure, by deleting the materials. Once deleted, your Floor Structure will be 0". Hit Ok, then that OSB will disappear. Hope this helps. I am assuming your using X15. Regardless, should work with any prev release. 1 Link to comment Share on other sites More sharing options...
