Why cant I edit this dimension anymore?
Studio-Red
13 hours ago, Studio-Red said:
Usually when you click on an object then the dimension number it lets you edit it but it is not for me. Did I do something?
The dimension marker may not be refrencing that object. The dimension value will change color when the object it references is selected, indicating that changing the value will move that object. Try hitting tab to select the next object and see if the value lights up, or add a new dimension marker to the center of the cabinet where you know that's what it's referencing.
