JOINING TWO WALLS
ChiefPat971
Good morning,
I am testing this software and when creating walls I am having difficulty joining two walls of different types.
Here are images that speak for themselves.
How can I join the two walls please?
Type wall 01:
Type wall 02:
Thank you for your help.
Patrick
@ChiefPat971What these gentlemen are saying is that you’re working too hard at your testing.  Chief works beautifully when you understand it.  It appears that you’ve interpreted “exterior” and “interior” layers to be only the outer visible surface materials, and all else to be the main layer.  The main layer should be only those things that make up the structural thickness of the walls.  In this case, just the block itself; not the insulation, plaster, etc. that is applied to the structural block.  The sprayed on insulation, air gap, interior and exterior material coatings, paint, etc. are all part of the inner and outer layers, inconsequential to the structure itself.  If you design your walls that way, things will work out much better.
