Partial wall under railings
bdammeyer
Go to solution Solved by bdammeyer,
4 minutes ago, bdammeyer said:
Thanks - it was a multi layer railing - I tried to make it a single layer wall (railing) but it wont let me delete the interior layer and it still shows something below the rail itself.
Interior layer looks ok.  That just represents the 2D cad line.  Try making the main layer "framing".
I dont have a material just called "framing" so i chose "fir framing 1". that didnt work.
Then i tried making it "opening (no Material)". Its showing the outline still but no material applied to the faces.  I can live with that.
Here is the plan file in case anybody wants to look into it further.  (had to zip it to get it under the file size limit)
230919 Freeman - Existing.zip
There were some changes to X14.  You need to check the box.
Deleting the floor structure is not really the solution even if it worked in you specific situation.
