StockmanBuilders Posted September 1, 2023 Share Posted September 1, 2023 Greetings all, I'm trying to create a built-in full-height cabinet next to a bed and I want there to be an opening niche on the right side of the cabinet face with shelves. For some reason the dialog box won't allow me to add or change shelves, it's grayed-out. Any suggestions? I know I can manually add shelves but it would be handy to just use the normal cab shelf tool. Here's what I'm seeing when I'm in that cabinet dialog box. TIA, Jessica Chief Architect Premier X15 on Mac Link to comment Share on other sites More sharing options...
MarkMc Posted September 1, 2023 Share Posted September 1, 2023 4 hours ago, StockmanBuilders said: Any suggestions? Split the front vertically. Add the shelves to the side with the opening. First set number of shelves, then distance between. Last set the bottom shelf distance from previous to match the bottom right side distance. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted September 5, 2023 Share Posted September 5, 2023 If you want one cabinet, you can't specify shelves on the right side, but you can modify the ones for the whole cabinet on the front side so that they will look right through the opening on the side. Link to comment Share on other sites More sharing options...
