HumbleChief Posted August 10, 2023 Share Posted August 10, 2023 Never had this happen. I dragged over a cook top into the plan and didn't place it into a base cab, now I can't select nor delete. Any help appreciated. https://www.dropbox.com/scl/fi/3dosqrp8m5gsj8emd7dn3/COOKTOP.plan?rlkey=ismswp0jwoxusahjxnqz5h2ko&dl=0 Link to comment Share on other sites More sharing options...
TeaTime Posted August 10, 2023 Share Posted August 10, 2023 10 minutes ago, HumbleChief said: I dragged over a cook top into the plan and didn't place it into a base cab You sure about that? 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted August 10, 2023 Author Share Posted August 10, 2023 Thanks Tea, The first cooktop I dragged over and not into a base cab and can't delete that one. The second cooktop I did drag into a base cab and can manage that one as expected. Can you select and delete that orphan cook top? And curious what that view is you are showing? Thanks Link to comment Share on other sites More sharing options...
Solution TeaTime Posted August 10, 2023 Solution Share Posted August 10, 2023 Yeah, you must have accidentally dropped it onto that cabinet - it's showing on the Preview because it belongs to it. See on the Accessories panel at the bottom there? Link to comment Share on other sites More sharing options...
HumbleChief Posted August 10, 2023 Author Share Posted August 10, 2023 AHA, got it. I must have accidentally dropped it on that cab on the way over to the floor plan. THANK YOU!! 1 Link to comment Share on other sites More sharing options...
