JuanR2 Posted August 7, 2023 Share Posted August 7, 2023 My plan view is what I want, one of the electrical switches NOT grouped with the other 3. But on perspective view, it groups the 4 of them! Is there a separation parameter I can edit? Putting them further apart is not a solution for my plan view, nor would it be possible on a narrow wall. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 7, 2023 Share Posted August 7, 2023 AFAIK that function is Automatic and can't be disabled , but perhaps if you save a Single switch to your Library as a new symbol as another non Electrical Symbol ( interior fixture perhaps ) it may allow what you want, but may have some side effects such as Auto Wire connections not working. M. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted August 7, 2023 Solution Share Posted August 7, 2023 Just change the height of it, up/down a mm should do the trick. Link to comment Share on other sites More sharing options...
JuanR2 Posted August 7, 2023 Author Share Posted August 7, 2023 5 hours ago, Kbird1 said: AFAIK that function is Automatic and can't be disabled , but perhaps if you save a Single switch to your Library as a new symbol as another non Electrical Symbol ( interior fixture perhaps ) it may allow what you want, but may have some side effects such as Auto Wire connections not working. M. 1 hour ago, DBCooper said: Just change the height of it, up/down a mm should do the trick. THANKS! it solves the situation! Never thought 1 mm could do so much. Link to comment Share on other sites More sharing options...
