Perspective 3D showing different than elevation
JamesBolger
I am showing an elevation for a motel with a fir wall tying into an existing block wall and it shows on my 3D perspective but not the elevation. For some reason elevation is showing a separate fir wall connected to the new one. I tried rolling the wall and it’s the same on both sides.. any suggestions
It looks to me like the lower picture is not displaying the block wall (probably because the layer is turned off) and that you are just seeing the framing for the wall behind it.
If this doesn't help, then you might want to post the plan.
Beat me to it once again, @DBCooper
That's what I was thinking too -- Try using the Back Clipped Cross Section to create an elevation of just that one wall to eliminate the back wall's framing, and check to make sure the layer is on in th Section View's layer set.
