Renocreations Posted June 26, 2023 Share Posted June 26, 2023 Hi, new to CA and inserted a window into a wall and the framing did not adjust for the opening. The studs show though the window when looking at the elevation and the wall detail does not show a window opening. Link to comment Share on other sites More sharing options...
DBCooper Posted June 26, 2023 Share Posted June 26, 2023 You need to manually rebuild the wall framing unless auto rebuild is turned on. 2 Link to comment Share on other sites More sharing options...
KenL-sdd Posted June 26, 2023 Share Posted June 26, 2023 @DBCooperYou are correct again! Good on you for helping users! I gave you another upvote! Link to comment Share on other sites More sharing options...
