Allen43 Posted June 20, 2023 Share Posted June 20, 2023 I recently updated to X15 and after doing so I have had a few problems. The last one I have to fix is my macro for auto cabinet label generation. I am by no means a programmer and I barely understood ruby when I made this macro. I have been trying to relearn but I still can't figure out what my problem is. I have attached my macro below and this is the error I have been getting: Evaluation Error: Ruby TypeError: no implicit conversion of nil into String Stack Trace: from eval:10:in `eval' from eval:10:in `block (2 levels) in <main>' from eval:4:in `loop' from eval:4:in `block in <main>' Any help is apricated. Thanks in advance! CabinetAutoLabel2.json Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 20, 2023 Share Posted June 20, 2023 46 minutes ago, Allen43 said: I recently updated to X15 This looks like one of Joe's very old macros.. Object type no longer reports the same, so without a checksum for nil, it will throw an error. might change the approach a bit, and redefine type in your code Quote # GET THE TYPE OF THE OBJECT, DOWNCASE, AND INDEX THE FIRST LETTER type = obj.type.to_s.downcase[0] and then when you analyze type later in the code Quote when 'w' and maybe add a check for yourself: Quote # CHECK TO ENSURE VARIABLES ARE NOT NIL AND REPORT IF ANY IS NIL if nomen.nil? puts "nomen is reporting nil and needs attention" nomen = "" end if width.nil? puts "width is reporting nil and needs attention" width = "" end if height.nil? puts "height is reporting nil and needs attention" height = "" end if depth.nil? puts "depth is reporting nil and needs attention" depth = "" end if hinging.nil? puts "hinging is reporting nil and needs attention" hinging = "" end Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 20, 2023 Share Posted June 20, 2023 1 hour ago, Renerabbitt said: This looks like one of Joe's very old macros. Not mine, not by a long shot. There are a lot of mistakes in this macro. Some NVPs in X15 have different names than in X14, including the fact that the Base Cabinets type is now "Base cabinet". it would be better to just assign: nomen = obj.type[0].upcase which would pick up B, W, F depending on the cabinet Also, the line hinging = owner.door_swing should be hinging = obj.door_swing In my macros I use comprehensive error handling by use of: begin some code... rescue exception code... end so that my macros will never result in "evaluation error" Link to comment Share on other sites More sharing options...
Allen43 Posted June 20, 2023 Author Share Posted June 20, 2023 3 hours ago, Renerabbitt said: This looks like one of Joe's very old macros.. Now that you mention it, I do think I used one of his macros when making this one. But it has been terribly frankensteined into whatever this is. Haha 2 hours ago, Joe_Carrick said: Not mine, not by a long shot. Not yours, but it is based off of your macro. I couldn't find much info on macros in chief so I used yours as one of my only resources for how all of this worked. 2 hours ago, Joe_Carrick said: begin some code... rescue exception code... end This is really smart, and I should take the time to implement this in the new macro I am going to have to make. 2 hours ago, Joe_Carrick said: nomen = obj.type[0].upcase Great idea! I definitely should have done this. 2 hours ago, Joe_Carrick said: Also, the line hinging = owner.door_swing should be hinging = obj.door_swing Thanks for letting me know! I'll make that change 3 hours ago, Renerabbitt said: Quote # GET THE TYPE OF THE OBJECT, DOWNCASE, AND INDEX THE FIRST LETTER type = obj.type.to_s.downcase[0] and then when you analyze type later in the code Quote when 'w' and maybe add a check for yourself: This is a much more concise approach that I will almost definitely implement this time. Link to comment Share on other sites More sharing options...
