Roxi0112 Posted June 13, 2023 Share Posted June 13, 2023 (edited) I've read through different posts regarding decks and I haven't come across any that are having the same issue as me. Does anyone know what's happening to my deck boards? I tried building a new deck by going over the one I have and it turns out the same. When I build a deck in another location it appears as it should. I have had this happen to me before so I'm wondering what I'm doing wrong. thank you for your suggestions. Deck.pdf Edited June 13, 2023 by Roxi0112 Link to comment Share on other sites More sharing options...
ericepv Posted June 13, 2023 Share Posted June 13, 2023 The procedure I would use would be to open the DBX for the deck and then specify the material in 'Planks, Joists' (at the very bottom of the 'Structure' tab). What have you tried already? It would help if you post the plan. Link to comment Share on other sites More sharing options...
KenL-sdd Posted June 13, 2023 Share Posted June 13, 2023 1 hour ago, Roxi0112 said: I've read through different posts regarding decks and I haven't come across any that are having the same issue as me. Does anyone know what's happening to my deck boards? I tried building a new deck by going over the one I have and it turns out the same. When I build a deck in another location it appears as it should. I have had this happen to me before so I'm wondering what I'm doing wrong. thank you for your suggestions. Deck.pdf 231.76 kB · 7 downloads Please post your plan. This way we can see the issue. Link to comment Share on other sites More sharing options...
