pjames Posted May 31, 2023 Share Posted May 31, 2023 I'm trying to have my stairs in my mat lists show the square footage of my flooring risers. Anyone have any ideas? Link to comment Share on other sites More sharing options...
TeaTime Posted June 1, 2023 Share Posted June 1, 2023 1 hour ago, pjames said: square footage of my flooring risers. maybe I'm misunderstanding the assignment, it's been known to happen, but if you're looking to calculate Tread material sq ft, you can change the materials list's "ext. stair tread" Count to =stair_section.width*(stair_section.tread_depth+stair_section.tread_overhang) 1 Link to comment Share on other sites More sharing options...
pjames Posted June 1, 2023 Author Share Posted June 1, 2023 Thanks this helped a lot. To clarify I'm trying to have both my Stair Tread & Riser Material Area included in my material list for flooring. That macro worked great for the tread sq ft - any idea on how to calculate the riser material area? It would be nice to set it up in the component defaults for stairs this way whenever they're drawn it will include in the material list. Link to comment Share on other sites More sharing options...
DBCooper Posted June 1, 2023 Share Posted June 1, 2023 Maybe stair_section.width * stair_section.riser_height? Keep in mind that these calculations probably won't be very accurate for any stair with starter treads, flares, or curves. They also don't handle landings. Not sure if there are any better solutions though. 1 Link to comment Share on other sites More sharing options...
pjames Posted June 1, 2023 Author Share Posted June 1, 2023 That worked perfect - thank you! Link to comment Share on other sites More sharing options...
TeaTime Posted June 1, 2023 Share Posted June 1, 2023 I was thinking about this last night -- I suppose depending on how specific you wanna get, you may consider (stair_section.width*stair_section.riser_height)-(stair_section.width*stair_section.tread_thickness) Link to comment Share on other sites More sharing options...
