Chiefuser3gc Posted May 22, 2023 Share Posted May 22, 2023 see attached pic this is my first project I'm trying to get this small section to draw trusses sitting on top of both top plates. When roof is built it puts top of top cord lower than top of wall. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 22, 2023 Share Posted May 22, 2023 what is your heel height? Link to comment Share on other sites More sharing options...
Chiefuser3gc Posted May 22, 2023 Author Share Posted May 22, 2023 not sure where to find that. I have the wall height set at 109 1/8" and locked but when it builds it it does this Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 22, 2023 Share Posted May 22, 2023 i think it is in build-> roof. or check the help Link to comment Share on other sites More sharing options...
Chiefuser3gc Posted May 22, 2023 Author Share Posted May 22, 2023 it is showing the plates missing at each corner is this a drop cord setting some where? Link to comment Share on other sites More sharing options...
TeaTime Posted May 22, 2023 Share Posted May 22, 2023 No such setting. But if your roof plane is generating too low walls will be cut down to fit under them. you probably just need to lift that roof plane up so its sitting where you want it. Take a cross section of that area and see where it's at, figure out how much it needs to come up and raise the roof plane by that amount. Link to comment Share on other sites More sharing options...
Chiefuser3gc Posted May 22, 2023 Author Share Posted May 22, 2023 I have another question about putting a fake dormer on top of the truss and roof sheeting. This is a customer request and not my idea but have to do what they want! is there a way to do this or just have to fake it in the drawing? Link to comment Share on other sites More sharing options...
TeaTime Posted May 22, 2023 Share Posted May 22, 2023 You can control that using the framing overbuild settings - https://www.chiefarchitect.com/videos/watch/1969/framing-an-overbuild-using-rafters.html?playlist=146 it doesn't cut away the actual materials but it controls how the framing generates. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 22, 2023 Share Posted May 22, 2023 On 5/22/2023 at 6:43 PM, TeaTime said: lift that roof plane up so its sitting where you want it. Expand to fo this, select the roof planes, then click the transform replicate button, and specify a positve number for Z. But really this should just build properly without having to do that. You might want to post the plan Link to comment Share on other sites More sharing options...
