trusses are showing birds mouth cut over wall
Chiefuser3gc
No such setting. But if your roof plane is generating too low walls will be cut down to fit under them.
you probably just need to lift that roof plane up so its sitting where you want it.
Take a cross section of that area and see where it's at, figure out how much it needs to come up and raise the roof plane by that amount.
I have another question about putting a fake dormer on top of the truss and roof sheeting.  This is a customer request and not my idea but have to do what they want!  is there a way to do this or just have to fake it in the drawing?
to fo this, select the roof planes, then click the transform replicate button, and specify a positve number for Z.
But really this should just build properly without having to do that. You might want to post the plan
